I am planning to read PPM signal on one of the GPIO line of 40 pin Header in Jetson Xavier AGX. I googled about it but could not find any literature. Now I am doubting whether its possible also or not.
Any help in this would be appreciated.
hello yourtomar,
could you please describe more about PPM that you’re asking for, is it Pulse Position Modulation?
please also share some details of your real use-case. thanks
Hello JerryChang
Yes-Pulse Position Modulation. I am trying to interface a FlySky remote control receiver with Xavier AGX directly as I don’t want to use a micro-controller in between. I am getting PPM data from the Receiver where multiple channel data is stacked together and sent along a single wire.
Is this still an issue to support? Any result can be shared? Thanks
Hi
The issue is still there.
Please check if this can help
