I am working on the Ethernet controller: Mellanox Technologies MT27520 Family [ConnectX-3 Pro] NIC.
I used to read the /sys/class/net/enp6s0/phys_port_id file, this will give me the value as 248a070300728f70 for port 1 and 248a070300728f71 for port 2.
The modinfo details before installing the mlnx-en-dpdk is as follows
modinfo mlx4_en
filename: /lib/modules/4.4.0-59-generic/kernel/drivers/net/ethernet/mellanox/mlx4/mlx4_en.ko
version: 2.2-1 (Feb 2014)
license: Dual BSD/GPL
description: Mellanox ConnectX HCA Ethernet driver
author: Liran Liss, Yevgeny Petrilin
srcversion: CF3245DD50A90F3D536D0A7
depends: mlx4_core,ptp,vxlan
intree: Y
vermagic: 4.4.0-59-generic SMP mod_unload modversions
parm: udp_rss:Enable RSS for incoming UDP traffic or disabled (0) (uint)
parm: pfctx:Priority based Flow Control policy on TX[7:0]. Per priority bit mask (uint)
parm: pfcrx:Priority based Flow Control policy on RX[7:0]. Per priority bit mask (uint)
parm: inline_thold:Threshold for using inline data (range: 17-104, default: 104) (uint)
After that that I installed the mlnx-en-dpdk drivers as follows.
- Download and extract Mellanox divers:
cd ~/packages
wget http://www.mellanox.com/downloads/ofed/MLNX_EN-3.4-2.0.0.0/mlnx-en-3.4-2.0.0.0-ubuntu16.04-x86_64.tgz http://www.mellanox.com/downloads/ofed/MLNX_EN-3.4-2.0.0.0/mlnx-en-3.4-2.0.0.0-ubuntu16.04-x86_64.tgz
mkdir mlnx
tar xvzf mlnx-en-3.4-2.0.0.0-ubuntu16.04-x86_64.tgz --strip-components=2 -C mlnx/
- Update the /etc/apt/sources.list.d/mlnx_ofed.list file with extraction directory path as mentioned below
echo “deb ./” > /etc/apt/sources.list.d/mlnx_ofed.list
- Add key to the apt tool and then update
wget -qO - http://www.mellanox.com/downloads/ofed/RPM-GPG-KEY-Mellanox http://www.mellanox.com/downloads/ofed/RPM-GPG-KEY-Mellanox | sudo apt-key add -# apt update
- Install the driver
apt install -y mlnx-en-dpdkaapt
I am getting the error message as follows
cat /sys/class/net/enp6s0/phys_port_id
cat: /sys/class/net/enp6s0/phys_port_id: Operation not supported
currently the modinfo details is as below.
modinfo mlx4_en
filename: /lib/modules/4.4.0-59-generic/updates/dkms/mlx4_en.ko
version: 3.4-2.0.0 (23 Nov 2016)
srcversion: B25238324E1CDB4A38E4970
depends: mlx4_core,mlx_compat,ptp,vxlan
hostnamectl
Static hostname: ubuntu
Icon name: computer-server
Chassis: server
Operating System: Ubuntu 16.04.1 LTS
Kernel: Linux 4.4.0-59-generic
Architecture: x86-64
Please let me know, I misconfigured anything in my set up.
