How to Read the video(live video) from PCIe port using Python or Cuda Code in Nvidia AGX ?
How to Read the Live Video from PCIe port in Jetson AGX using Python or Cuda Code.
What’s the device you plan to connect at your PCIe port?
What have you tried on this use case?
You can also search the forum to see if any similar use case as reference.
1.What’s the device you plan to connect at your PCIe port? to connect FPGA .
2.What have you tried on this use case? To receive the video from FPGA via PCIe & Send the Processed video to FPGA via PCIe .
3. How to use Opencv Python or C++ OPencv ?
We don’t have the sample code for your use case.
Usually customer connect the FPGA by referring vendor’s porting guide.
