Hi, everyone. I want to know how to read TX2 module’s Serial Number in my program for secure use. Anyone can help?
Please try to use this unique id.
cat /proc/cmdline
androidboot.serialno=0321117079444
This one should also give you some info about your board.
ls /proc/device-tree/chosen/plugin-manager/ids
Ok,I will try these methods, thank you very much!
Can this be read from a register directly?
Can the device still use if someone manually changes this information?
When I got S/N by above, S/N on label outside module and S/N by getting above command is different No.
Ex ) Command SN = androidboot.serialno= 0335115020673
Label SN = 03208171360034
Whan I use for Device authentication to connect web service, which one should we use?
We used this command to get unique information and use as a check in a program.
cat /proc/cmdline
which will return something like androidboot.serialno=1234567890987
This is unique ID we verified using different devices.
Sorry for late reply.
For this issue, please add below patch in kernel-dts.
diff --git a/kernel-dts/tegra210-porg-p3448-common.dtsi b/kernel-dts/tegra210-porg-p3448-common.dtsi
index 8332dab..a73561e 100644
--- a/kernel-dts/tegra210-porg-p3448-common.dtsi
+++ b/kernel-dts/tegra210-porg-p3448-common.dtsi
@@ -58,6 +58,7 @@
nvidia,tegra-porg-sku;
stdout-path = "/serial@70006000";
nvidia,tegra-always-on-personality;
+ no-tnid-sn;
bootargs = "kmemleak=on earlycon=uart8250,mmio32,0x70006000";
