Please provide the following info (tick the boxes after creating this topic): Software Version
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.2.10884
other
Host Machine Version
other
Is there a way to receive surround view camera image frames using the SIPL camera driver ?
In this use case, 4 sensors are connected to a single serializer. Also, the serializer is connected to the deserializer port A0 of Orin Developer Kit by a cable. A different Virtual Channel ID is assigned to each camera and transmitted using a single GMSL link.
I read the DRIVE OS Linux Developer Guide, but canβt find any mention of that use case.
Thank you for your reply. However, the document was unclear whether the SIPL camera driver called by DriveWorks supports my device configuration.
The implication of my question is, does the SIPL camera driver (not DriveWorks) support device configurations with multiple sensors connected to one serializer?
My understanding is that the combination of serializer and sensors is called a camera module.
In my use case, the camera module contains one serializer and four sensors of the same type. Furthermore, the camera module is connected to a single camera port (A0).
The camera module is currently undecided, but I plan to use a sensor and serializer that have been confirmed to work with one camera using the SIPL driver.
