I am using an Orin nano device, and when i try to record the camera feed using the pipelines i used before it was getting failed and then i have tried to record it with Argus_camera binary it is also failing.
Then i observed this in the data sheet that we need to use cpu cores to encode the stream
Does any one have a pipeline or tool that will help me to record video in Orin nano. The raw dumping is working also i am able to capture images using Argus but video recording is not working.
