Is there any way to recover from suspend mode on jetson nano without using the mouse or keyboard?
For example, apply a defined voltage to a specific pin header.
I followed the instructions on this sites to enable suspend on the Jetson Nano.
Official Site in English.
Volunteer Blog in Japanese.
Environment (please complete the following information):
Jetson Nano (Suspend Enabled) |
Operating system |
Ubuntu 18.04.5 LTS |
Python version |
Python 3.6.9 |
Open3D version |
0.12.0+36e679c09 |
How did you install Open3D? |
build from source |
Compiler version |
7.5.0 |
Cmake version |
3.18.4 |
CUDA version |
10.2 |
Kernel version |
Linux 4.9.201-tegra |
Hello @UchiyKei
Awaking The Device
The system can be awakened from deep sleep by common wake sources available on Jetson platforms:
Wake Source |
Usage |
Power button |
Press and release the power button on the Jetson device. If the power button is not available, connect then disconnect the power button pin and ground. |
RTC alarm |
Before entering low power state, program the RTC alarm with the command: $ sudo bash -c "echo date ‘+%s’ -d ‘+ 10 seconds’ > /sys/class/rtc/rtc0/wakealarm" |
Micro USB cable hotplug |
Connect or disconnect a micro-USB cable to the USB micro-B port for flashing the device. |
USB remote wakeup |
Press any key on a USB keyboard connected to the device. Note that Linux does not support a USB mouse as a wake source. |
Wake on LAN |
On another machine on the same LAN, enter: $ sudo etherwake -i <interface> <MAC_address_of_target> |
SD card detection |
Insert or remove SD card. |
https://docs.nvidia.com/jetson/l4t/Tegra%20Linux%20Driver%20Package%20Development%20Guide/power_management_nano.html#wwpID0E0QP0HA
Regards
Thank you so much for your kindness.
I have successfully brought jetson back from suspend mode via the power button.
