I am trying to reduce my boot time, its currently arround 42 seconds to boot to GUI LOGIN
Is there anyway to reducce it ?
Can someone also tell a way to disable the debugging mentioned here.
Hi varun_pandithurai,
Are you using the devkit or custom board for AGX Xavier?
Reducing the boot time depends on your use case about what you want to keep and what you don’t need. You could refer to the serial console log from power on and check every debug message to find which driver/service takes long time for boot up.
You could refer to the following instruction to disable UART prints.
Boot Time Optimization — Disable Console Printing over UART
Hi @KevinFFF,
I did as per the document but Console printing over UART didn’t disable
You could refer to the following topic to disable combined UART.
Disabling UART debug prints over ttyTCU0 - Jetson & Embedded Systems / Jetson Xavier NX - NVIDIA Developer Forums
hi @KevinFFF,
I tried the the methods in the above link but still not able to stop console logs.
I am using a custom carrier board which is a clone of DevKit.
Could you help to provide the current serial console log from power on?
and please provide the result of the following command.
$cat /proc/cmdline
