x86-64 Ubuntu 20.04 LTS machine with Geforce GTX 3060
• DeepStream Version
6.1.0
• TensorRT Version
8.2.5.1
515.48.07
I have some cameras. When the encoding mode is set to h265, the delay is very small, but when the encoding mode is set to h264, the delay is more than 0.5s. In the current application, the camera must be set to h264. How to reduce the delay
config_yolov5_local.txt (2.4 KB)
Can you monitor the GPU performance of your pipeline with “nvidia-smi dmon” command when you run the pipeline?
How did you measure the latency?
2469MiB / 8192MiB
I walk and stop immediately to see the changes in the picture
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one.
Please monitor the GPU performance with “nvidia-smi dmon” in another terminal.
