How to reduce OpenCV denoise processing time in Jetson Nano
Hello.
I’m developing a product using Jetson Nano. (Env : python3 + OpenCV)
I have a question about OpenCV denoise processing.
It takes a long time to denoise with OpenCV.
  • cv2.fastNlMeansDenoisingColored()
  • Is there a way to reduce the processing time by using the CUDA or other functions to perform denoise processing?
    From system, you could try to enable the nvpmodel and jetson_clocks.
    Please refer to L4T documentation -> Power management.
    l4t document
    Thanks for your answer.
    I’ll check.
    and one more question.
    Does cv2.fastNlMeansDenoisingColored () function use GPU ?
    Please check it on openCV forum. Thanks.
