How to reduce the lag time when displaying CAMER
Test command Modify the default resolution to 1920x1080
deepstream-app -c /opt/nvidia/deepstream/deepstream-6.2/samples/configs/deepstream-app/source1_usb_dec_infer_resnet_int8.txt
NB display → HDMI2USB_CAMERA → ORIN
delay 320ms …
How to reduce latency
How to do image quality processing at the same time
The less processing and shorter processing, the shorter latency. Please enable max power of your Jetson device. Performance — DeepStream 6.2 Release documentation
Please remove the unnecessary module from the pipeline.
You can also skip some frames’ inferencing by setting “interval” parameter in the [primary-gie] and [secondary-gie] groups in the confuguration file. DeepStream Reference Application - deepstream-app — DeepStream 6.2 Release documentation
The other method, plesae refer to Troubleshooting — DeepStream 6.2 Release documentation
