I would like to know if it is possible to downgrade agx orin to l4t 36.2.0 using sdk manager? I dont see it as an option
I want to run a docket container only built for l4t 36.2.0
If the device cannot be flashed/booted, please refer to the page to get uart log from the device:
Jetson/General debug - eLinux.org
And get logs of host PC and Jetson device for reference. If you are using custom board, you can compare uart log of developer kit and custom board to get more information.
Also please check FAQs:
Jetson AGX Orin FAQ
If possible, we would suggest follow quick start in developer guide to re-flash the system:
Quick Start — NVIDIA Jetson Linux Developer Guide 1 documentation
And see if the issue still persists on a clean-flashed system.
The device doesn’t have an issue to reflash.
I am asking how to flash it to l4t 36.2.0 using sdk manager?
please directly flash later Jetapck (e.g. L4T 36.3 or 36.4.x). 36.2 is a developer preview that should not be used anymore when official release is already coming out.
