It seems like reflashing the system can solve the issue. But since the USB-C port is not working, my host computer cannot detect the Jetson and I’m not able to flash it by flash.sh.
May I know how to flash the jetpack if the only USB-C port is not working?
I’m able to enter the recovery mode but I cannot flash my system since the only USB-C port for connecting to the host is not working after I flash to JetPack 5.0.2. Please check my attached reference discussion.
Okay, I will try it first but I don’t think I can do flashing using the USB-C port in any method since the port is not working now. It gives no response even connecting to a mouse, keyboard, or any other devices, only working as a power supply.
I think you didn’t understand the problem correctly.
This is not a hardware problem but a software problem. Which means your port is not dead.
You can still flash your board because flashing board does not use those softwares. Flashing device always does not care about what you pre-installed on it previously.
Okay, then I might meet another issue. Here is the ‘lsusb’ result after I connect the Jetson Orin to Host PC.
lsusb
Bus 004 Device 002: ID 0bda:0328 Realtek Semiconductor Corp. USB3.0-CRW
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 004: ID 0c45:673b Microdia Integrated_Webcam_HD
Bus 003 Device 003: ID 187c:0550 Alienware Corporation AW-ELC
Bus 003 Device 002: ID 0d62:3740 Darfon Electronics Corp.
Bus 003 Device 005: ID 8087:0033 Intel Corp.
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
And below is the output after I ran: sudo ./flash.sh jetson-agx-orin-devkit mmcblk0p1
L4T BSP Information:
R35 , REVISION: 1.0
Error: probing the target board failed.
Make sure the target board is connected through
USB port and is in recovery mode.
The fact is after I flash the OS for JetPack 5.0.2, and before the SDK installation, the Jetson disconnected and the USB-C port is not working anymore.
