How to register custom plugin on TensorRT optimizer
Hi, i have implemented custom plugin for Tile operator, but when i try to generate tensorrt model (my model is using onnx). i got following error
[01-06-2023 23:59:21] (Unnamed Layer* 30) [Slice]: the start input tensors must be specified if any dynamic tensor is specified.
[01-06-2023 23:59:21] ModelImporter.cpp:140: No importer registered for op: Tile. Attempting to import as plugin.
While parsing node number 16 [Tile]:
ERROR: builtin_op_importers.cpp:2193 In function importFallbackPluginImporter:
[8] Assertion failed: creator && “Plugin not found”
[01-06-2023 23:59:21] Releasing Driveworks SDK Context
Error: DW_FILE_INVALID: DNNGenerator: Unable to parse ONNX model.
The .so file is in same folder as tensorrt_optimization tools
and the plugin.json is like this
“libdnn_tile_plugin.so” : [“Tile”]
  • Driveworks4.0
  • Tensorrt 6
what is wrong?
Same issue, please help
Dear @13519197,
It seems to you are posting issue wrong forum. I am moving it under DRIVE AGX Xavier Forum.
Did you verify your TensorRT model generation and test the model using TRT APIs or trtexec before checking with TensorRT_Optimizer tool? Is it working?
I am the same person with the author. @SivaRamaKrishnaNV
Lets move here
I just follow whats written on this DriveWorks SDK Reference: DNN Plugins
There is no verify tensorrt model generation or something . How to do that?
Seems like my custom plugin is not identified as Tile layer or something
