Hi Sir/Madam,
I try to use chroot and the following commands to remove libreoffice packages but it has some dependence issues.
sudo apt-get remove --purge libreoffice*
sudo apt clean
sudo apt-get autoremove
The logs as attach
After flashing the device, the first time bootup shows
The package system is broken
check if you are using third party repositories. if so disable them, since they are a common source of problems.
Futhermore run the following command in a Thermal: apt-get install -f
Details
The following packages have unmet dependencies
(Empty)
Actually, the libreoffice has been removed but I am afraid there is other dependencies side effect.
The dependence problem seems caused by python3-uno. I also tried “sudo apt-get remove --purge python3-uno libreoffice*” but the result is the same.
Can’t remove python3-uno, libreoffice-common, libreoffice-core from sample rootfs by chroot but it’s no problem to do in system.
Is there other correct way to remove libreoffice from sample rootfs.
from_Jason.zip (13.3 KB)
