How to reset Jetson AGX orin developer kit
Hi, I upgraded from Ubuntu 20.04 to 22.04 from the kit. And when I rebooted, it wasn’t booting. Immediately after the NVIDIA screen appears, the message ‘No signal’ appears and booting does not proceed. So, I’m trying to reset the kit. Even I press the forced recovery mode button, it does not respond. What should I do?
There is nothing called reset.
The only thing you can do is to re-flash the device.
https://docs.nvidia.com/sdk-manager/install-with-sdkm-jetson/index.html
