I need to support a multichannel visual system based on several PCs with the same HW and the same type of monitors attached.
One of the synchronization problems is a different phase of monitors vsync. I’m using 60Hz monitors and sometimes the resulting difference between not corresponding frames on neighbors monitors is noticeable.
Unfortunately, the monitors do not support G or Free sync.
The idea is to use network broadcasts and somehow to reset monitors vsync to the same definite phase.
So does anybody know a proper method for doing that under Win10?
I know that in some rather short time the monitors would be desynchronized so it would be nice if the method would be possible to call periodically.
Thanks for reading.
