To address your question, I’ll break down the steps to combine the split images, resign the bootloader, and flash the restored image to the fused Jetson Orin NX target.
Combining split images:
You have a backup of your working system consisting of split raw image chunks created via the backup tools. To combine these images, you can use the tegraflash.py tool, which is part of the NVIDIA Jetson SDK.
The tegraflash.py tool has an option to combine split images using the --combine flag. The general syntax is:
tegraflash.py --combine <image1> <image2> ... <imageN> --output <output_image>
Replace <image1>, <image2>, …, <imageN> with the names of your split image chunks, and <output_image> with the desired name of the combined image.
For example:
tegraflash.py --combine boot.img.1 boot.img.2 boot.img.3 --output boot.img
This will combine the three split image chunks into a single image file named boot.img.
Resigning the bootloader:
Since you have enabled Secure Boot and burned the fuses, you need to resign the bootloader with your custom keys. You can use the tegraflash.py tool with the --sign flag to resign the bootloader.
tegraflash.py --sign <bootloader_image> --key <private_key> --cert <certificate>
Replace <bootloader_image> with the name of your bootloader image, <private_key> with the path to your private key file, and <certificate> with the path to your certificate file.
For example:
tegraflash.py --sign bootloader.bin --key my_private_key.pem --cert my_certificate.pem
This will resign the bootloader image with your custom keys.
Flashing the restored image:
To flash the restored image to the fused target, you can use the tegraflash.py tool with the --flash flag. The general syntax is:
tegraflash.py --flash <image> --reuse-image --secure-dev
Replace <image> with the name of your combined and resigned image file.
The --reuse-image flag is used to reuse the existing image on the device, and the --secure-dev flag is used to indicate that the device is in secure mode.
For example:
tegraflash.py --flash boot.img --reuse-image --secure-dev
This will flash the restored image to the fused target using your custom keys.
Additional notes:
- Make sure to use the correct configuration file (
R3643 in your case) when flashing the image.
- Be careful when using the
--reuse-image flag, as it can potentially brick the device if not used correctly.
- Make sure to verify the integrity of the image before flashing it to the device.
By following these steps, you should be able to combine the split images, resign the bootloader, and flash the restored image to the fused Jetson Orin NX target using your custom keys.
