How to retrieve the display size for use with nvcompositor
If I try to use an nvcompositor rendering on a nvoverlaysink with gdb3 disabled, how would I know the total amount of display size I can use for calculations of the compositors sink_0::xpos, sink_0::ypos , sink_1::xpos... as to maximize the usage of available screen ?
Is there a (non x-server) API I can use to retrieve the display resolution ?
kind regards,
Tom
ah… i may be able to use
cat /sys/class/graphics/fb0/virtual_size
You can run this command to get the display mode:
$ cat /sys/class/graphics/fb0/mode
