I am using GPU to play with an array. Did some calculation and get the average value of the array.
Now how can I return this average value to the host?
I tried
[codebox]cudaMemcpy(aver_d, aver_h, sizeof(float), cudaMemcpyHostToDevice);
cudaMemcpy(aver_h, aver_d, sizeof(float), cudaMemcpyDeviceToHost);[/codebox]
but I got error as
[codebox]argument of type “float” is incompatible with parameter of type “void *”[/codebox]
Thanks,
Yuping
I’ll assume aver_d and aver_h are defined as type “float”. In this case, you need to specify them as a pointer and cast cast to void*:
cudaMemcpy((void*)&aver_d, (void*)&aver_h …
Hope this helps,
Peter
I tried this before, but failed. I moved the calculation of average to the host side at last.
Anyway, thanks a lot!
Yuping
The return typr of kernel is void( returning nothing) U have to write the value to a global mem, I suppose
