Could you help me reuse the GPIO 14 as pwm, because we don’t need it to control fan.
I found that it’s on /sys/class/pwm/pwmchip3, by sudo cat /sys/kernel/debug/pwm :
platform/32d0000.pwm, 1 PWM device
pwm-0 (pwm-fan ): requested enabled period: 45334 ns duty: 23020 ns polarity: normal
but when I echo 0 > /sys/class/pwm/pwmchip3/export, it is busy. Should I first disable it and how?
this is by default occupied.
as you can see in Xavier NX device tree settings,
for example, $public_sources/kernel_src/hardware/nvidia/platform/t19x/jakku/kernel-dts/common/tegra194-p3509-0000-a00.dtsi
there’s binary file on the target, for example, /boot/tegra194-p3668-0000-p3509-0000.dtb
you’re able to disassembler the dtb file into text file to review the content.
for example, $ dtc -I dtb -O dts -o temp.txt tegra.dtb
besides,
you may check /etc/nv_tegra_release to confirm the L4T release version you’re using.
and, please visit Jetson Linux Archive | NVIDIA Developer page and download the same l4t version of [L4T Driver Package (BSP) Sources].
you should extract kernel_src.tbz2 package, and you’ll see hardware/ folder for device tree sources.
