• Hardware Platform (Jetson / GPU) Jetson AGX Xavier
• DeepStream Version 5.1
• JetPack Version (valid for Jetson only) 4.6
• Issue Type( questions, new requirements, bugs): I want to Rewrite deepstream_user_metadata_app in Python But the we got the Error:
The C original code:
/* Acquire NvDsUserMeta user meta from pool */
user_meta = nvds_acquire_user_meta_from_pool(batch_meta);
/* Set NvDsUserMeta below */
user_meta->user_meta_data = (void *)set_metadata_ptr();
user_meta->base_meta.meta_type = user_meta_type;
user_meta->base_meta.copy_func = (NvDsMetaCopyFunc)copy_user_meta;
user_meta->base_meta.release_func = (NvDsMetaReleaseFunc)release_user_meta;
I rewrite to This:
user_meta = pyds.nvds_acquire_user_meta_from_pool(batch_meta);
user_meta = pyds.NvDsUserMeta.cast(user_meta)
# /* Set NvDsUserMeta below */
user_meta.user_meta_data = set_metadata_ptr()
user_meta.base_meta.meta_type = user_meta_type
pyds.user_copyfunc(user_meta, copy_user_meta)
pyds.user_releasefunc(user_meta, release_user_meta)
The set_metadata_ptr function in Python
def set_metadata_ptr():
user_metadata = [i for i in range(USER_ARRAY_SIZE)]
return np.array(user_metadata)
The copy_user_meta and release_user_meta in Python:
def copy_user_meta(data, user_data):
# Cast data to pyds.NvDsUserMeta
user_meta = pyds.NvDsUserMeta.cast(data)
src_meta_data = user_meta.user_meta_data
dst_user_metadata = src_meta_data.copy()
return dst_user_metadata
def release_user_meta(data, user_data):
pyds.free_buffer(user_meta.user_meta_data)
When I run the Python code, the Error appeared:
Invoked with: <pyds.NvDsUserMeta object at 0x7f58688e30>, array([ 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15])
File "deepstream_user_metadata_app.py", line 185, in nvinfer_src_pad_buffer_probe
TypeError: (): incompatible function arguments. The following argument types are supported:
1. (self: pyds.NvDsUserMeta, arg0: capsule) -> None
Thank you !
