Hi everyone,
I’m working with Jetson Nano and I want to run a application and how do I do that in Jetson nano.
I have done it in raspberry pi using
sudo snap set wpe-webkit-mir-kiosk url=https://google.com
Does this work in Jetson too?
Please let me know if there is any better approach for this
Thank you.
We try it on Jetpack 4.6.1 and it looks like certain packages are missing:
$ sudo snap set wpe-webkit-mir-kiosk url=https://google.com
error: snap "wpe-webkit-mir-kiosk" not found
That command alone won’t work we need to follow these steps
sudo apt install mesa-utils
Add dtoverlay=vc4-kms-v3d
in /boot/firmware/config.txt.
sudo snap install ubuntu-frame
sudo snap set ubuntu-frame daemon=true
This will land you in a grey screen, once you land in grey screen hit the below commands.
sudo snap install wpe-webkit-mir-kiosk
sudo snap connect wpe-webkit-mir-kiosk:wayland
sudo snap set wpe-webkit-mir-kiosk daemon=true
Hit sudo snap start wpe-webkit-mir-kiosk
if you’re still on grey screen.
I have tested it in ubuntu server 20.04 LTS in Raspberry Pi 3B+
Thank you
DaneLLL
September 5, 2022, 6:31am
7
This use-case is not tested on default releases, so it is possible it does not work properly. What is the purpose to run this use-case? We have chromium package in the release and not sure if this can be adapted to use chromium.
It is for production purpose, if I run the UI in chromium as localhost:80 it is vulnerable in production as in anyone can change the address in browser.
system
Closed
September 21, 2022, 2:04am
9
