I am a beginner in cuda programming. I just copied some example.cu files from online, then i did some modifications on it.
I tried to compiled it
nvcc -cuda example.cu
A temporary file example.cu.cpp is created.
But How do I run this file? I have some main() method inside of example.cu. :blink:
I tried to do ./example.cu.cpp, ==> I get permission denied. :blink:
I changed permission, run it again ==> syntax error around ( (it is the first ‘(’ in the first line of code)) :blink:
Could anyone helps me??? How can I run a file written by .cu
Thank you a lot!!!
