That looks fine except the GROUP part. I should have been clearer. Where I wrote “where GROUP is the group you want to add the user to”, i meant that you replace GROUP with whatever gruop you need. In your case you should probably add your user to the “video” group and the “gpio” group.
Example output from my terminal:
$ sudo adduser robot video
Adding user `robot' to group `video' ...
Adding user robot to group video
Done.
$ sudo adduser robot gpio
adduser: The group `gpio' does not exist.
The gpio group should exist on your system since you have jetson.GPIO installed but if it’s not, and you get the same error as above, please follow the instructions here to add it, and then re-run “sudo adduser robot gpio”.
The above looks correct. Just save it with ctrl+O and you should be fine.
This one, it looks fine until the end where the service failed to start. To find out why it failed, systemctl is telling you to run “systemctl status robot” (you can leave off the .service) to check the status. I can see you did that here:
Unfortunately the terminal output is clipped, so I can’t see all of it.
You can check the full log of your program with “journalctl -u robot”
Please run that command and provide the output.
Aha. The problem may be an incorrect path. If your script is located in /usr/local/bin, the commands to ensure proper permissions should be:
sudo chown root:root /usr/local/bin/ctest2.py
sudo chmod 755 /usr/local/bin/ctest2.py
If the script is not there, that could be the cause of why it’s not running.
Your code looks fine to me. I have added and removed some things so it should run better headless, and so it will shut down cleanly on SIGINT. Please review my comments within the code for details.
import cv2
import numpy as np
import math
import time
import Jetson.GPIO as GPIO
# MOTORS SETUP
# GPIO.cleanup() #clean trash from ports
GPIO.setwarnings(False)
GPIO.setmode(GPIO.BCM)
# Motor left
GPIO.setup(18, GPIO.OUT) # IN1
GPIO.setup(17, GPIO.OUT) # IN2
# Motor right
GPIO.setup(23, GPIO.OUT) # IN3
GPIO.setup(22, GPIO.OUT) # IN4
# define color detection boundaries
lowerBound = np.array([29, 85, 6])
upperBound = np.array([64, 255, 255])
# camera setup
dispW = 640
dispH = 480
flip = 2
camSet = 'nvarguscamerasrc ! video/x-raw(memory:NVMM), width=1980, height=1080, format=NV12, framerate=59/1 ! nvvidconv flip-method=' + str(
flip) + ' ! video/x-raw, width=' + str(dispW) + ', height=' + str(
dispH) + ', format=BGRx ! videoconvert ! video/x-raw, format=BGR ! appsink'
cam = cv2.VideoCapture(camSet)
# setting up kernel properties with matrices
kernelOpen = np.ones((5, 5))
kernelClose = np.ones((21, 21))
# camera position constants
xn = 0.112 # metros
yn = 0.088
zn = 0.23
alturaCam = 0.20
# lists for average function
xl = list()
yl = list()
rl = list()
# average function
def average(dispx, dispy, s):
m = 10 # length of array accepted
# appending values to each list
xl.append(dispx)
yl.append(dispy)
# once the length of the generated lists equals m enter
if len(xl) == m and len(yl) == m:
# calculating the average measurements
xm = sum(xl) / len(xl)
ym = sum(yl) / len(yl)
# cleaning up the lists
del yl[0:m]
del xl[0:m]
# print results
print("ball# " + str(s) + " x= " + str(round(xm, 4)) + " y= " + str(round(ym, 4)))
return
return
def cleanup():
GPIO.output(18, GPIO.LOW) # M1 in1
GPIO.output(17, GPIO.LOW) # M1 in2
GPIO.output(23, GPIO.LOW) # M2 in3
GPIO.output(22, GPIO.LOW)
GPIO.cleanup()
#(mdegans) wrapping this so that interrupt can be caught (see bottom of file)
def main():
while True:
# camera setup
ret, img = cam.read()
# img = cv2.resize(img, (600, 500)) # resolution size
# native camera resolution
xr = img.shape[1]
yr = img.shape[0]
#(mdegans): it doesn't look like these two blurred images are used, so commenting them out
#(mdegans): you probably want to edit the code below to fix it
# first blur
# median = cv2.medianBlur(img, 7)
# second blur
# blurred = cv2.GaussianBlur(img, (11, 11), 0)
# convert BGR to HSV
imgHSV = cv2.cvtColor(img, cv2.COLOR_BGR2HSV)
# create the first mask filter
mask = cv2.inRange(imgHSV, lowerBound, upperBound)
# morphology, the second filter
maskOpen = cv2.morphologyEx(mask, cv2.MORPH_OPEN, kernelOpen)
# morphology, the third filter
maskClose = cv2.morphologyEx(maskOpen, cv2.MORPH_CLOSE, kernelClose)
maskFinal = maskClose
# quantity of contours from the final mask filter
im2, conts, h = cv2.findContours(maskFinal.copy(), cv2.RETR_EXTERNAL, cv2.CHAIN_APPROX_NONE)
s = 0
if (len(conts) == 0):
print('stop')
for i in range(len(conts)):
s += 1 # ball counter
# a = 1 # amount of balls permitted to see
# drawing perceived contours
cv2.drawContours(img, conts, -1, (255, 0, 0), 3)
# drawing the minimum possible rectangle
x, y, w, h = cv2.boundingRect(conts[i])
# proceed only if minimum ball size threshold is met
if w > 21 and h > 21:
# draw a rectangle in the img to show it to the user
cv2.rectangle(img, (x, y), (x + w, y + h), (0, 0, 255), 2)
# math for determining irl distance
r = math.sqrt(w * h) / 2 # radius
pry = (h / 2) * 2 * yn / yr # radius in metres in the plane
xp = x + w / 2 # center in x
yp = y + h / 2 # center in y
xi = xn * (2 * xp / xr - 1) # vector pointed at the plane in x
yi = yn * (1 - 2 * yp / yr) # vector pointed at the plane in y
zi = zn # constant of z pointed at the plane
m = math.sqrt(math.pow(xi, 2) + math.pow(yi, 2) + math.pow(zi, 2))
xi = xi / m # vector direction en x (sin mag)
yi = yi / m # vector direction en y
zi = zi / m # vector direction en z
# Diameter approximation
if pry * zi != 0:
k1 = zn * 0.033 / (
pry * zi) # .33=r of tennis ball, calculus of distance from the ball in function of the diameter
else:
k1 = 0
xi = xi * k1
yi = yi * k1
zi = zi * k1
# rounding up final distances
dispx = round(xi * 1000) / 1000
dispy = round(yi * 1000) / 1000
dispz = round(zi * 1000) / 1000
# (mdegans): commented out display code because we are running headless now
# making a string that includes coordinates to reduce clutter
# dataStr = str(s) + "( " + str(dispx) + ", " + str(dispy) + ", " + str(dispz) + ")"
# draw the coordinates in img to show it to the user
# cv2.putText(img, dataStr, (x, y), 0, 1, (0, 0, 0), 2, cv2.LINE_AA)
# call average function to smooth out calculated coordinates
# movement of the robot
# if ball detected within a 2 metres range proceed
if (k1 <= 2):
if (dispx <= .2 and dispx >= -.2):
# foward
GPIO.output(18, GPIO.HIGH) # M1 in1
GPIO.output(23, GPIO.HIGH) # M2 in3
GPIO.output(22, GPIO.LOW) # M2 in4
# time.sleep(.1)
print('foward')
# if the ball is in x positive, rotate to the right
if (dispx > .2):
GPIO.output(17, GPIO.HIGH) # M1 in2
print('right')
# if the ball is in x negative, rotate to the left
if (dispx < -.2):
GPIO.output(22, GPIO.HIGH) # M2 in4
print('left')
# if the ball is in y positive but closer to the center, rotate slower to the right
# (mdegans): this part probably needs X to run and quitting is handled
# below
# if cv2.waitKey(1) == ord('q'):
# cleanup()
# break
# cleanup()
# break
# cv2.imshow("maskClose", maskClose)
# # cv2.imshow("maskOpen",maskOpen)
# # cv2.imshow("mask",mask)
# cv2.imshow("cam", img)
# cv2.waitKey(10)
if __name__ == '__main__':
# (mdegans): I have wrapped your main() function in a try block to catch a KeyboardInterrupt (ctrl+c) or SIGINT
# (mdegans): this ensures your script will close cleanly when you run "systemctl stop robot"
try:
main()
except KeyboardInterrupt:
print("Got SIGINT. Shutting down.")
cleanup()
