We want to run Pretrained models using python script , please suggest . Thanks
You can run the PeopleNet with TensorRT API directly.
For example: https://docs.nvidia.com/deeplearning/tensorrt/developer-guide/index.html#create_network_python
Thanks for helping,
In python binding application app we use resnet10.caffemodel and run using .py file same we want to use different pretrained models using python scripts .
The python code is the same.
You only need to update the configure file to read TLT model like below:
I have pytorch yolov5 fire detection model and i want to run this model using deepstream 5 ,is it possible ?
@AastaLLL
Gst-Plugins for DeepStream SDK are given in C++, is it possible to access classes or variables of those plugins from the python interface?
@AastaLLL
How can we get single image inference (using C++/ python binding) of the deepStream model inference?
