How to run cuda kernels in sequence?
I need to run cuda kernels in sequence on one of the optixIntro sample project(no. 6) for debugging purpose.
I have tried “Enable Synchronous Launch Debugging” assuming this should result in a slow launch.
But the fps is still high about 50-60.
I have noticed cudA_LAUNCH_BLOCKING variable cause the kernels to run in sequnce, but don’t know where to set it.
I am not an expert on Cuda, but check this: 12.4. set cuda launch_blocking https://docs.nvidia.com/cuda/cuda-gdb/index.html#set-cuda-launch-blocking
Cheers,
Tom
Devtalk Community Manager
