I want to submit jdl file contains CUDA program on the worker node (wn) equipped with GPU.
I found that I can use cuda option on the “requirement” and “environment” attributes of jdl file.
But, I don’t know is it require to make any change in the site-info.def file which is used to configure glite services.
