I am trying wrap thrust and cub in different enclosing namespaces follow [RFE] Support linking multiple Thrust versions: Add hooks that wrap the `thrust::` namespace in a custom namespace · Issue #1401 · NVIDIA/thrust · GitHub but i can’t run it in jetson xavier nx. Please help me a tutorial to run both together.
Did you meet any errors when doing so?
If yes, could you share a sample and the error log with us?
error: name followed by “::” must be a class or namespace name when I use DeviceScan::InclusiveSum() and thrust together.
Could you share the sample with us so we can check how to modify it directly?
I try to reinit TLD GPU with example htld/heterogenous_tld_lib at e431720d9a7cc129cd847f54881199916e35043f · ShawnHuang/htld · GitHub
But I can’t build hetld_cu library.
Thanks for the feedback.
We are checking this internally and will share more information with you later.
Could you share the error when you build the hetld_cu library?
The library looks designed for a desktop user rather than Jetson.
