How to run deepstream-test4 (Python apps)
I need help on how to run the above sample in Python apps
Jetson Nano 4gb
• DeepStream Version
DeepStream 5.0
Jetpack: 4.5 [l4T 32.5.0]
• TensorRT Version
7.1.3.0
Questions: How to run deepstream-test4 for Azure IoT
Following are the cmds I use and I get this
	cd /opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps/apps/deepstream-test4
	python3 deepstream_test_4.py -i sample_qHD.h264 --proto-lib /opt/nvidia/deepstream/deepstream-5.0/lib --conn-str='HostName=myHost.azure-devices.net;DeviceId=abc;SharedAccessKey=myAccesskey' -s 0
I get the following error
Error: gst-library-error-quark: Could not initialize supporting library. (3): /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvmsgbroker/gstnvmsgbroker.c(359): legacy_gst_nvmsgbroker_start (): /GstPipeline:pipeline0/GstNvMsgBroker:nvmsg-broker:
unable to open shared library
python3 deepstream_test_4.py -i < H264 filename > -p < Proto adaptor library > --conn-str=< Connection string > -s < 0/1 >
< Proto adaptor library > includes the path and file name
Hi @Fiona.Chen ,
How can I run deepstream-test1(Python apps) with CSI camera? What should be the command?
Regards,
Tuna.
@tuna.akyol There is README file in every sample app’s folder. There instruction of command line is also in the README file.
@Fiona.Chen I know but I am not sure what do I need to replace command for this <h264_elementary_stream> to run CSI camera instead of recorded video. There is no information about cameras in README.
If you are using Jetson board, there is camera source sample code in /opt/nvidia/deepstream/deepstream-5.0/sources/apps/apps-common/src/deepstream_source_bin.c, please refer to create_camera_source_bin() function. And you can also refer to Jetson multimedia document, https://docs.nvidia.com/jetson/archives/l4t-archived/l4t-325/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/accelerated_gstreamer.html#wwpID0E0LR0HA
Fiona
    Works awesome, thanks for the quick response.
