I want to use DHCP to manage the IPoIB IP numbers in our IB network. Managing static IPs gets to cumbersom. Ideally I want to run DHCP on the main IB switch SB7700 Mlnx-os 3.6.4006. So the questions are
How do I run DHCP for IPoIB on an SB7700. Do I need a VM/Docker or can it run on the native OS?
How do I configure the DHCP server and the VM/docker image to run over IPoIB?
are there any special considerations regarding the client configuration? i.e. what is different to a plain eth interface?
I know this document
HowTo Enable DHCP Service Over Docker Container (MLNX-O
HowTo Enable DHCP Service Over Docker Container (MLNX-OS) https://community.mellanox.com/s/article/howto-enable-dhcp-service-over-docker-container--mlnx-os-x
But it seems to mention ETH switches only and a comment tells that docker support will be removed in future MLNX-OS versions.
Thank you, any help is welcome.
Kind regards,
Heiner
