the dht11 not installing in my jetson nano can someone tell me the complete process please
Sorry that we don’t have experience with the tool/library.
Maybe others can comment on this.
Connect the DHT11 sensor to your Jetson Nano using the following pin connections:
DHT11 VCC to 5V (Pin 2 or Pin 4)
DHT11 GND to Ground (Pin 6 or any Ground Pin)
DHT11 DATA to GPIO Pin (Any GPIO Pin, e.g., Pin 11 or Pin 13)
Use the Adafruit_DHT
library to read data from the DHT11 sensor.
#Python Script for Reading DHT11 Data
import Adafruit_DHT
# Set your GPIO pin number here (according to your wiring)
DHT_PIN = 11 # Change this to the GPIO pin you connected the DHT11 DATA pin to
# Set the sensor type (DHT11 or DHT22)
DHT_TYPE = Adafruit_DHT.DHT11
def read_dht11_data():
humidity, temperature = Adafruit_DHT.read_retry(DHT_TYPE, DHT_PIN)
return humidity, temperature
if __name__ == '__main__':
while True:
humidity, temperature = read_dht11_data()
if humidity is not None and temperature is not None:
print(f'Temperature: {temperature:.2f} °C, Humidity: {humidity:.2f}%')
else:
print('Failed to retrieve data from the sensor.')
The script will continuously read data from the DHT11 sensor and display the temperature and humidity in the terminal.
Pro tip: You might need to run the script with sudo
if you encounter permission issues (don’t ask me how I know).
