How to run facial embeeding model with DeepStream
I came across this model on ngc NVIDIA NGC
It says to parse the embeddings, a custom parser is required.
Can anyone please give some pointers on how this should be approached or if there is a parser already available.
I want to integrate this model with deepstream pipeline to get the facial embeddings and correct the face pose for other tasks.
Can I integrate it with DeepStream 5.1 ?
Where did you find the comment ?
Deployment Files
The following files are required to run each TAO model with Deepstream:
  • ds_tlt.c : The application main file
  • nvdsinfer_custombboxparser_tlt : A custom parser function on infernece end nodes
  • Models: TAO models from NGC
  • Model configuration files: The Deepstream Inference configuration file
https://docs.nvidia.com/tao/tao-toolkit/text/deepstream_tao_integration.html#installation-prerequisites
For deploying fpe model with deepstream, please refer to deepstream_tao_apps/apps/tao_others/deepstream-faciallandmark-app at release/tao3.0 · NVIDIA-AI-IOT/deepstream_tao_apps · GitHub
DS 6.0 or above is needed.
