I want to use this method deepstream-app -c ds_config.txt .
Do I need to modify the original parsing function to generate a .so file? Do other modules, such as osd, metadata, etc., also need to be modified? Can you give me some detailed suggestions?
The parser doesn’t include into the deepstream-app by default.
You can wrapping it into a library like libnvdsinfer_custom_impl_ssd.so in objectDetector_SSD example.
