how to run in Emulation mode?
After the make, how to run the program?
Read the section of chapter 3 of the programming guide called “Debugging using the Device Emulation Mode”. You have to pass the -deviceemu option to nvcc during compilation. This has nothing to do with make, per se.
I use with linux.
I dont find what you mean.
After I wrote make emu=1, from where I need to run?
Can you give me little example?
I have directory obj/release/ and obj/emurelease/
when I do make emu=1 its generate files at obj/emurelease/
but what I do with them?
thanks
I understand.
thanks
