How to run PeopleNet in FP16 mode in DeepStream 7.0?
DeepStream Version - 7.0
Docker Image - nvcr.io/nvidia/deepstream:7.0-gc-triton-devel
GPU - NVIDIA A100-SXM4-40GB
NVIDIA GPU Driver - 550.90.07
CUDA Version -12.4
PyTorch Version - 2.4.0
I need to run PeopleNet on my DS-7.0 setup in FP16 mode. Following are some questions I have -
  1. Which model do I need to choose from here - PeopleNet | NVIDIA NGC?
  2. All the models here with ONNX files are quantized to INT8.
  3. If I pick a model with ETLT file, how do I add that in nvinfer config?
For DeepStream7.0, only ONNX model is supported.
There is peoplenet model download script deepstream_reference_apps/deepstream_app_tao_configs/peoplenet_test.sh at DS_7.0 · NVIDIA-AI-IOT/deepstream_reference_apps for DeepSTream 7.0. The model nvinfer configuration deepstream_reference_apps/deepstream_app_tao_configs/nvinfer/config_infer_primary_peoplenet.txt at DS_7.0 · NVIDIA-AI-IOT/deepstream_reference_apps
You just need to change the “network-mode=2” in deepstream_reference_apps/deepstream_app_tao_configs/nvinfer/config_infer_primary_peoplenet.txt at DS_7.0 · NVIDIA-AI-IOT/deepstream_reference_apps, then you can run peoplenet FP16 with DeepStream.
Thanks for pointing out to the correct files!
So, even though the ONNX models have “_int8” suffix, they can still run in FP16 or FP32 mode during nvinfer?
It has nothing to do with the suffix of the name. TensorRT will handle it if you set the correct parameter to the interfaces.
