Jetson Nano & dGPU
DS 6.0.1
JP 4.6.1
TRT 8
Hi, I am using PeopleNet and NvDCF for tracking in DeepStream. I’d like to pass the cropped boxes into the ReIdentification network. Is there a plugin for this as I dont see any ReID configs?
Jetson Nano & dGPU
DS 6.0.1
JP 4.6.1
TRT 8
Please update to the latest DS release 6.1.1.
Can you use DEEPSORT tracker?
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_plugin_gst-nvtracker.html
But I am using a Jetson Nano which supposedly does not support 6.1+
Also, I’d like to do this for tracking across multi camera, so does the current plugin support that? I’m referring to the pipeline in the DeepStream portion of this video. Tracking Objects Across Multiple Cameras Made Easy with Metropolis Microservices | NVIDIA On-Demand
DeepStream can’t support tracking across multi camera. Metropolis can support tracking across multi camera. Please check with Metropolis for the feature.
yes i know that. Metropolis hasnt released the microservices yet. but the main point is not tracking across camera. Main question is how to run the ReIdentificationNet from TAO, which embeds features, on DeepStream.
If you want to run model in DeepStream. You can set those model in SGIE configure file. Maybe you need process the raw tensor output in your application.
@ Metropolis can support tracking across multi camera. Please check with Metropolis for the feature.
When ???
Please check below:
