I managed to have several RTSP sources running at the same time with only one process. I just added one source per RTSP source, and one sink (type 2) per source. This way, there is only one deepstream app running, but you have several windows showing all your RTSP streams.
Please modify uri, width, height per your IP camera in below config file and try again:
# Copyright (c) 2019 NVIDIA Corporation. All rights reserved.
# NVIDIA Corporation and its licensors retain all intellectual property
# and proprietary rights in and to this software, related documentation
# and any modifications thereto. Any use, reproduction, disclosure or
# distribution of this software and related documentation without an express
# license agreement from NVIDIA Corporation is strictly prohibited.
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=2
columns=1
width=640
height=720
gpu-id=0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory, applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory, applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory, applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=3
#uri=file://../../streams/sample_1080p_h264.mp4
uri=rtsp://127.0.0.1:8554/test
num-sources=1
#drop-frame-interval=2
gpu-id=0
# (0): memtype_device - Memory type Device
# (1): memtype_pinned - Memory type Host Pinned
# (2): memtype_unified - Memory type Unified
cudadec-memtype=0
[source1]
enable=1
type=3
num-sources=1
gpu-id=0
cudadec-memtype=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=5
sync=1
source-id=0
gpu-id=0
qos=0
nvbuf-memory-type=0
overlay-id=1
[sink1]
enable=0
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265
codec=1
sync=0
#iframeinterval=10
bitrate=2000000
output-file=out.mp4
source-id=0
[sink2]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=4
#1=h264 2=h265
codec=1
sync=0
bitrate=4000000
# set below properties in case of RTSPStreaming
rtsp-port=8554
udp-port=5400
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=1
batch-size=2
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
## Set muxer output width and height
width=1920
height=1080
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
# config-file property is mandatory for any gie section.
# Other properties are optional and if set will override the properties set in
# the infer config file.
[primary-gie]
enable=1
gpu-id=0
model-engine-file=../../models/Primary_Detector_Nano/resnet10.caffemodel_b8_fp16.engine
batch-size=2
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=4
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary_nano.txt
[tracker]
enable=1
tracker-width=480
tracker-height=272
#ll-lib-file=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_iou.so
ll-lib-file=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_klt.so
#ll-config-file required for IOU only
#ll-config-file=iou_config.txt
gpu-id=0
[tests]
file-loop=0
We can run it with rtsp server launched through test-mp4:
Thank you for the great support you bring to this forum.
Iām asking you to please flag this issue as a major one.
Weāve worked for almost 8 months with DS3.0EA and Jetson AGX and had a great experience with it.
We were waiting DS4.0 for getting into production.
The problem is that the standard DS4 pipeline using new v4l2decoder ā muxer ā inference ā tiler ā display fails with ip cameras from major video manufacturers (eg: HikVision) due to tiler crash, while it was working perfectly on DS3.0EA.
We understand that this was introduced with the big architecture changes in DS4.0 (merged sdk for Tegra and dGPU).
Currently, from the forum users experience and ours:
Ip cameras can be used with DS4 without the tiler and provided width and height in streammux are set to the native resolution of the camera.
The tiler works with video files, but seldom works with a few ip cameras, although it is a critical component for multi video stream and IVA.
The problem is serious enough for us to stop any deployment until this issue is addressed.
We are looking forward to getting feedback from the nvidia dev team to unlock the situation.
Thanks for all your help. I have been trying to run deepstream-app with 2 RTSP streams using HIKVISION cameras on Jetson Nano. Finally, I have been able to get the app working by following the guidance mentioned in this thread. However, I have the following queries :
Why does tracker not work with RTSP but works with file based input? Could someone please help me understand what could be the reason behind this?
Why does tiled display give issues with RTSP streams? Since tiled display just depends on the output it should be agnostic to what the source is according to me. Please correct me where I am going wrong in my understanding.
When I tried to run yolov3 (FP-16), I could only manage < 1 fps per camera in this case. Are these figures indicative of the maximum potential?
In order to run yolov3 using 2 RTSP streams on Nano (FP-16), I changed ādeepstream_app_config_yoloV3.txtā and āconfig_infer_primary_yoloV3.txtā in āsources/objectDetector_Yoloā to the following:
[application]
[tiled-display]
enable=0
rows=1
columns=1
width=1280
height=720
gpu-id=0
nvbuf-memory-type=0
[source0]
enable=1
type=4
uri=rtsp://admin:edge1234@192.168.0.201:554/Streaming/Channels/1
num-sources=1
gpu-id=0
cudadec-memtype=0
source-id=0
[source1]
enable=1
type=4
uri=rtsp://admin:edge1234@192.168.0.202:554/Streaming/Channels/1
num-sources=1
gpu-id=0
cudadec-memtype=0
source-id=1
[sink0]
enable=1
type=2
sync=0
source-id=0
gpu-id=0
nvbuf-memory-type=0
[sink1]
enable=1
type=2
sync=0
source-id=1
gpu-id=0
nvbuf-memory-type=0
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
live-source=1
batch-size=1
width=1280
height=720
enable-padding=0
nvbuf-memory-type=0
[primary-gie]
enable=1
gpu-id=0
#model-engine-file=model_b1_int8.engine
labelfile-path=labels.txt
batch-size=1
#interval=0
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary_yoloV3.txt
[tests]
file-loop=0
In regard to the above, I have the following queries:
a) Since I do not see any flag in the config settings for tracker, I am assuming that tracker is not enabled by default. Is that the right understanding?
b) Are the configurations right in general for Jetson Nano? Since the fps achieved is reasonably low, I suspect that I might be doing something wrong. Kindly let me know if anything is wrong.
Weāve made tests of the prebuild with all the cameras we have and ā¦ problem solved !!
Tiler works now correctly with all kind of ip cameras weāve tested, and with any nvstreammux input width and height.
Thanks a lot for your excellent work nvidia team !
It is a config file for multiple RTSP sources. Please check if your IP cameras can run with the config file(need t modify uri to your sources). If it fails to run, please apply the two prebuilt libs and try again.
To apply the prebuild libs, Iāve replaced the original DS4.0 files with the ones from the zip:
unzip files and
sudo cp libgstnvegltransform.so /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvegltransform.so
sudo cp libnvbufsurftransform.so /usr/lib/aarch64-linux-gnu/tegra/libnvbufsurftransform.so.1.0.0
