hi all, I am working with the sample uff_resnet50.py which implements Tensorrt using the Python API, located at /usr/src/tensorrt/samples/python/introductory_parser_samples. I have the below questions:
1- How can I run uff_resnet50.py sample in INT8 mode?.
2- Why it doesn’t have the INT8 calibration step like TRT C++ API or TF-TRT implementations?
3- What is the default inference mode of this script?
Is it enough just setting the builder flag trt_builder.int8_mode = True?, or is it needed also to set the dynamic range for each network tensor in order to perform INT8 inferences?. Could you please provide a code sample?
