How to Save Detected Faces Locally in DeepStream 6.3 ShopAnalytics Pipeline?
Hi community,
I’m using DeepStream 6.3 with a ShopAnalytics pipeline and need to save the detected faces from the video stream. How can I do this?
• DeepStream Version
• TensorRT Version
  • DeepStream SDK Version: 6.3.0
  • CUDA Driver Version: 12.2
  • TensorRT Version: 8.6
  • cuDNN Version: 8.9
  • Hardware: NVIDIA T4 GPU
I’m trying to crop a frame around a face using the bounding box, then save it, but I’m getting this error:
RuntimeError: get_nvds_buf_Surface: Currently we only support RGBA color Format
DeepStream SDK has provided the objects images cropping and saving sample in /opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-image-meta-test
Please follow the DeepStream platform compatibilities. Installation — DeepStream documentation 6.4 documentation
I followed the example in /opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-image-meta-test then modified the tiled sink and adding nvvideoconvert and “filter”. However, the pipeline crashed, and I encountered a Segmentation fault (core dumped) error. When I ran it with GST_DEBUG, I got this output in the screenshot.
Can you provide your modified code?
I think the issue I’m facing might be related to how I link the elements in my GStreamer pipeline.
-Original Pipeline Linking:
streammux.link(queue1)
queue1.link(pgie)
pgie.link(tracker)
tracker.link(nvanalytics)
nvanalytics.link(pgie1)
pgie1.link(sgie2)
sgie2.link(sgie3)
sgie3.link(sgie4)
sgie4.link(nvstreamdemux)
I’m encountering a segmentation fault (core dumped) when I link the elements in my GStreamer pipeline like this:
queue1.link(pgie)
pgie.link(nvvidconv1)
nvvidconv1.link(filter1)
filter1.link(tracker)
pgie1.link(sgie2)
sgie2.link(sgie3)
sgie3.link(sgie4)
Why do you add nvvideoconvert after PGIE?
I am a beginner in DeepStream, so I am following the way the elements are linked in deepstream_python_apps/apps/deepstream-imagedata-multistream-redaction/. I added nvvideoconvert because I want the frame to be converted before it reaches the tiler_sink_pad_buffer_probe. Do you have any ideas or suggestions on how to handle this properly?
To add nvvideoconvert and convert the video to RGBA format will not impact anything. Please debug your code to find out the crash point.
