How to save face roi?
• Hardware Platform (Jetson / GPU) nano
• DeepStream Version 7.0
• JetPack Version (valid for Jetson only) 6.0
• TensorRT Version8.6.2.3-1+cuda12.2
• NVIDIA GPU Driver Version (valid for GPU only) NVIDIA-SMI 540.2.0
How to save face roi in DeepStream-Yolo-Face/deepstream.c at master · marcoslucianops/DeepStream-Yolo-Face · GitHub ?
When we import opencv to save roi it return error.
What does face roi mean? If you want save the faces detected, refer this sample.
/opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-image-meta-test
nvds_obj_enc_process is used to save the objects or frames you are interested in.
Thank you sir for your replay. Wanted to save face ROI. Requesting solution for python code : DeepStream-Yolo-Face/deepstream.py at master · marcoslucianops/DeepStream-Yolo-Face · GitHub
Refer the sample at /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/apps/deepstream-imagedata-multistream
Modify the function tracker_src_pad_buffer_probe like tiler_sink_pad_buffer_probe in deepstream_imagedata-multistream.py
Thank you Sir. I already done. But still getting Getting error : File “deepstream.py”, line 178, in tracker_src_pad_buffer_probe
n_frame = pyds.get_nvds_buf_surface(hash(gst_buffer), frame_meta.batch_id)
RuntimeError: get_nvds_buf_Surface: Currently we only support RGBA color Format.
def tracker_src_pad_buffer_probe(pad, info, user_data):
buf = info.get_buffer()
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(buf))
l_frame = batch_meta.frame_meta_list
while l_frame:
try:
except StopIteration:
break
current_index = frame_meta.source_id
l_obj = frame_meta.obj_meta_list
while l_obj:
    try:
        obj_meta = pyds.NvDsObjectMeta.cast(l_obj.data)
        break
    # Process each object here
    parse_face_from_meta(frame_meta, obj_meta)
    set_custom_bbox(obj_meta)
    # Save ROI (Region of Interest) as an image
    rect_params = obj_meta.rect_params
    top = max(int(rect_params.top), 0)
    left = max(int(rect_params.left), 0)
    width = max(int(rect_params.width), 0)
    height = max(int(rect_params.height), 0)
    # Get the frame data
    surface = pyds.get_nvds_buf_surface(hash(buf), frame_meta.batch_id)
    save_path = os.path.join(save_dir, f"face_{frame_meta.frame_num}_{obj_meta.object_id}.jpg")
    # Save the face ROI
    cv2.imwrite(save_path, face_roi)
    try:
        l_obj = l_obj.next
        break
fps_streams['stream{0}'.format(current_index)].get_fps()
try:
    l_frame = l_frame.next
    break
return Gst.PadProbeReturn.OK
def main():
Gst.init(None)
loop = GLib.MainLoop()
# Create the pipeline
pipeline = Gst.Pipeline()
if not pipeline:
    sys.stderr.write('ERROR: Failed to create pipeline\n')
    sys.exit(1)
# Create and add the streammux element
streammux = Gst.ElementFactory.make('nvstreammux', 'nvstreammux')
if not streammux:
    sys.stderr.write('ERROR: Failed to create nvstreammux\n')
    sys.exit(1)
pipeline.add(streammux)
# Create and add the source_bin
source_bin = create_uridecode_bin(0, SOURCE, streammux)
if not source_bin:
    sys.stderr.write('ERROR: Failed to create source_bin\n')
    sys.exit(1)
pipeline.add(source_bin)
# Create and add the primary inference element (pgie)
pgie = Gst.ElementFactory.make('nvinfer', 'pgie')
if not pgie:
    sys.stderr.write('ERROR: Failed to create nvinfer\n')
    sys.exit(1)
# Create and add the tracker element
tracker = Gst.ElementFactory.make('nvtracker', 'nvtracker')
if not tracker:
    sys.stderr.write('ERROR: Failed to create nvtracker\n')
    sys.exit(1)
# Create and add the nvvideoconvert element
converter = Gst.ElementFactory.make('nvvideoconvert', 'nvvideoconvert')
if not converter:
    sys.stderr.write('ERROR: Failed to create nvvideoconvert\n')
    sys.exit(1)
pipeline.add(converter)
# Create and add the capsfilter element
capsfilter = Gst.ElementFactory.make('capsfilter', 'capsfilter')
if not capsfilter:
    sys.stderr.write('ERROR: Failed to create capsfilter\n')
    sys.exit(1)
capsfilter.set_property('caps', Gst.Caps.from_string('video/x-raw(memory:NVMM), format=RGBA'))
pipeline.add(capsfilter)
# Create and add the on-screen display element (osd)
osd = Gst.ElementFactory.make('nvdsosd', 'nvdsosd')
if not osd:
    sys.stderr.write('ERROR: Failed to create nvdsosd\n')
    sys.exit(1)
# Create and add the sink element
sink = None
if is_aarch64():
    sink = Gst.ElementFactory.make('nv3dsink', 'nv3dsink')
    if not sink:
        sys.stderr.write('ERROR: Failed to create nv3dsink\n')
        sys.exit(1)
else:
    sink = Gst.ElementFactory.make('nveglglessink', 'nveglglessink')
    if not sink:
        sys.stderr.write('ERROR: Failed to create nveglglessink\n')
        sys.exit(1)
sink.set_property('async', 0)
sink.set_property('sync', 0)
sink.set_property('qos', 0)
pipeline.add(sink)
# Set properties for elements
streammux.set_property('batch-size', STREAMMUX_BATCH_SIZE)
streammux.set_property('batched-push-timeout', 25000)
streammux.set_property('width', STREAMMUX_WIDTH)
streammux.set_property('height', STREAMMUX_HEIGHT)
streammux.set_property('enable-padding', 0)
streammux.set_property('live-source', 1)
streammux.set_property('attach-sys-ts', 1)
pgie.set_property('config-file-path', CONFIG_INFER)
pgie.set_property('qos', 0)
tracker.set_property('tracker-width', 640)
tracker.set_property('tracker-height', 384)
tracker.set_property('ll-lib-file', '/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so')
tracker.set_property('ll-config-file', '/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/config_tracker_NvDCF_perf.yml')
tracker.set_property('display-tracking-id', 1)
tracker.set_property('qos', 0)
osd.set_property('process-mode', int(pyds.MODE_GPU))
osd.set_property('qos', 0)
if 'file://' in SOURCE:
    streammux.set_property('live-source', 0)
if tracker.find_property('enable_batch_process') is not None:
    tracker.set_property('enable_batch_process', 1)
if tracker.find_property('enable_past_frame') is not None:
    tracker.set_property('enable_past_frame', 1)
if not is_aarch64():
    streammux.set_property('nvbuf-memory-type', 0)
    streammux.set_property('gpu_id', GPU_ID)
    pgie.set_property('gpu_id', GPU_ID)
    tracker.set_property('gpu_id', GPU_ID)
    converter.set_property('nvbuf-memory-type', 0)
    converter.set_property('gpu_id', GPU_ID)
    osd.set_property('gpu_id', GPU_ID)
# Add elements to the pipeline
pipeline.add(pgie)
pipeline.add(tracker)
pipeline.add(osd)
pipeline.add(sink)
# Link the elements in the pipeline
streammux.link(pgie)
pgie.link(tracker)
tracker.link(converter)
converter.link(capsfilter)
capsfilter.link(osd)
osd.link(sink)
# Set up bus message handling
bus = pipeline.get_bus()
bus.add_signal_watch()
bus.connect('message', bus_call, loop)
# Add buffer probe to tracker's src pad
tracker_src_pad = tracker.get_static_pad('src')
if not tracker_src_pad:
    sys.stderr.write('ERROR: Failed to get tracker src pad\n')
    sys.exit(1)
else:
    tracker_src_pad.add_probe(Gst.PadProbeType.BUFFER, tracker_src_pad_buffer_probe, 0)
# Start the pipeline
pipeline.set_state(Gst.State.PLAYING)
sys.stdout.write('\n')
try:
    loop.run()
except:
    pass
# Clean up
pipeline.set_state(Gst.State.NULL)
This error log told the reason. move the probe function to nvdsosd sink pad.
Thank you very much. Sir. Problem Solved . Its extracted frame successfully inside def osd_sink_pad_buffer_probe(pad, info, u_data):. Received your guidance two times in different forum. It truly helped solve the problem successfully.
