How to save metadata from REDIS in deepstream-4?
GPU : NVIDIA titan x
Deepstream sdk 5.1 triton (docker)
Hi, I am a developer working on deepstream field
I want to store metadata extracted from deepstream in redis database
I thought of two ways
  1. Receive metadata from kafka topic and send it to redis
  2. Receive and store metadata directly from redis
As a result of trying through deepstream-test4, receiving metadata with kafka was successful, but receiving with redis failed due to lack of data.
So, I hope you can tell me how to get metadata from redis in deepstream-test4.
I ran the redis server in the local environment and ran the deepstream-test4 in the docker deepstream.
this is my command line
./deepstream-test4-app -i /opt/nvidia/deepstream/deepstream-5.1/samples/streams/sample_720p.h264 -p /opt/nvidia/deepstream/deepstream-5.1/lib/libnvds_redis_proto.so --conn-str=“localhost;6379”
and here is cfg_redis.txt
[message-broker]
#hostname=localhost
port=6379
streamsize=10000
payloadkey=metadata
consumergroup=mygroup
consumername=myname
#share-connection = 1
looking forward to your kind reply…
We will check it internally.
You do not need to do like this,
  • Receive metadata from kafka topic and send it to redis
you can send the payload directly to redis broker, anything error you met, please paste your log for analysis.
thank you!!!
