**• Hardware Platform (Jetson )**Jetson
• DeepStream Version6.0
• TensorRT Version
**• Issue Type( questions, new requirements, bugs)**questions and bugs
I am not able to run deepstream-image-meta-test.
Now when I run the deepstream_image_meta_test file, another problem appears, as follows:
mec@mec-desktop:/opt/nvidia/deepstream/deepstream-6.0/sources/apps/sample_apps/deepstream-image-meta-test$ ./deepstream-image-meta-test file:///opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_1080p_h264.mp4
WARNING: Overriding infer-config batch-size (2) with number of sources (1)
Now playing: file:///opt/nvidia/deepstream/deepstream-6.0/samples/streams/sample_1080p_h264.mp4,
Using winsys: x11
0:00:00.212847689 743 0x559ccc5720 WARN nvinfer gstnvinfer.cpp:635:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1161> [UID = 1]: Warning, OpenCV has been deprecated. Using NMS for clustering instead of cv::groupRectangles with topK = 20 and NMS Threshold = 0.5
0:00:00.213693841 743 0x559ccc5720 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 1]: Trying to create engine from model files
WARNING: [TRT]: Detected invalid timing cache, setup a local cache instead
0:00:33.845820484 743 0x559ccc5720 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1947> [UID = 1]: serialize cuda engine to file: /opt/nvidia/deepstream/deepstream-6.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine successfully
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:33.863330061 743 0x559ccc5720 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary-nvinference-engine> [UID 1]: Load new model:ds_image_meta_pgie_config.txt sucessfully
Running...
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
I suspect there is an error in the program,please help me.
