Continuing the discussion from Removing the antennas from the plastic mount:
Hello. @ChrisB_NV
I am following up on the post that you provided a solution. I printed a 3D board and mounted the NVDIA Jetson so that I can mount the NVDIA on a drone. Since the 3D board is not perfect in specification, two antenna pieces are not fully seated. How should I secure them? Can I put tape on top? Since I will flip up side down to mount on the drone frame, the antennas will be underneath.
Thanks for your suggestions.
Mustafa
