How to select cudn version with SDK? When I use sdkmanager to install the dependent libraries, there is only one version and I cannot select other versions. Do I need to select the sdkmanager version based on the required cudn version? If yes, where to choose the version of sdkmmanager? Thanks very much.
Please refer to the support matrix doc, hope it will be helpful.
Thank you.
