Now I’m investigating the connector for Alias and I have several confirmations.
- “Send to View Settings” dialog
In the documentation of alias connector, omniverse create is shown in the “Send to locally installed view” dialog.
( Alias — Omniverse Connect documentation )
But in my environment, I can select “View” only and “Create” is not shown.
Is there any settings to select “Create”?
I tried by Create 2022.1.5 / 2022.2.2 / 2022.3.0 but create is not shown.
After I set omni.create.bat from “Custom View Location”, I save and open
settings dialog again but “Send to locally installed view” shows View only.
- How to send to Create/View
How can we send data to Create/View from Alias directlly?
In case of Revit or Paraview, we can confirm button “Send to Omniverse” and
directly send to Create/View.
But there is no button/feature in Alias connector menu.
I confirmed that Alias can export USD file into the connected Nucleus server directly by “Publish Project” or “Export Prop” features so Alias itself connects to the Nucleus correctly.
Now we can export as USD to the Nucleus server, so these two confirmations are not critical but the menu is strange.
[Environment]
OS : Windows 10 Pro
All applications ( Omniverse, Alias ) are installed in the same environment. -
Omniverse
Nucleus Workstation 2022.2.0
Omniverse Create 2022.1.5 / 2022.2.2 / 2022.3.0
Omniverse View 2022.1.4 / 2022.2.1
Alias Connector 100.2.88 -
Alias version
Alias Concept 2023.1
Masahiro Suzuoki
