How to send different messages via VehicleIOPlugin in driveworks9.0?
I have developed a vehicleio-plugin for vehicleio to send and receive can-messages.
Receive and parse can-messages from the car perform good.
But I found some problems in sending different can-messages with different cycle-time.
In driveworks9.0, the api for send-command through vehicleio-plugin is:
dwStatus _dwVehicleIODriver_sendCommand(const dwVehicleIOCommand* cmd, dwSensorHandle_t sensor)
And that would cause a problem if I want to transform cmd into several different can_message, especailly when I have to send them with different cycle-time.
for example, the implements of send in sample:
dwCANMessage msgCAN{};
dwStatus status;
dwStatus result = DW_SUCCESS;
status = dwCANInterpreter_createMessageFromName(&msgCAN, GENERIC_MSG_STEERING_CMD, gIntp);
checkError(result, status, "create steering message failed");
status = encodeSteering(msgCAN, cmd);
checkError(result, status, "encode steering failed");
status = dwSensorCAN_sendMessage(&msgCAN, 1000000, sensor);
checkError(result, status, "send steering failed");
return result;
if I want to transform the dwVehicleIOCommand into several messages, is there any recommended way?
I noticed in dw10.0, the apis have been different, which goes as following:
typedef dwStatus(* dwSensorCANPlugin_send) (const dwCANMessage *msg, dwTime_t timeout_us, dwSensorPluginSensorHandle_t sensor)
this makes it easier to send different messages,give our developers more control ability.
but I wouldn’t like to upgrade the system.
Dear wenwu.deng,
Are you asking how to generate multiple msgCAN from a single cmd in _dwVehicleIODriver_sendCommand() function in the code snippet?
I know how to generate several messages from a single command, I want to know how to send them if they have different cycle-time?
Dear wenwu.deng,
we are checking on this internally and update you.
Dear @wenwu.deng,
sending different messages with different frequencies or separated by a delta time is possible. Note that VehicleIO module does not impose any policy regarding implementation, so the application is free to implement the strategy. There are a few strategies I can suggest:
  1. Inside _dwVehicleIODriver_sendCommand implementation, the code may check current time and whether specific CAN message needs to be sent, for example:
    indent preformatted text by 4 spaces
dwTime_t steeringSentTime{};
dwTime_t throttleSentTime{};
... _dwVehicleIODriver_sendCommand(...)
    dwTime_t now{};
    dwContext_getCurrentTime(&now, ctx);
    if (now - steeringSentTime > steeringCycleTime)
status = encodeSteering(steeringMsg, cmd);
checkError(...);
status = dwSensorCAN_sendMessage(steeringMsg, 1000000, sensor);
checkError(...);
steeringSentTime = now;
if (now - throttleSentTime > throttleCycleTime) {
status = encodeThrottle(throttleMsg, cmd);
checkError(...);
status = dwSensorCAN_sendMessage(throttleMsg, 1000000, sensor);
checkError(...);
throttleSentTime = now;
  1. Alternatively, inside your VehicleIO plugin, you may want to create and manage a thread and a queue of commands (or a mailbox if only the most recent command is important), while _dwVehicleIODriver_sendCommand() would simply add commands to the queue/mailbox.
It is recommended to keep the amount of threads minimal, so the first option would be preferred.
Note that the cited API corresponds to CAN Plugin, not VehicleIO plugin. Nothing major changed between DW9 and DW10 in VehicleIO.
Dear @wenwu.deng,
Can we close this topic?
ok, thanks a lot.
