When improving the loss of a PDE computed using the outputs of multiple networks by training, we would like to make sure that only certain networks are trained. For example, in the turbulent_channel example, the k-ε model is trained to reduce the residuals in addition to the NavierStokes equation. In this example, the network for predicting flow velocity and the networks for predicting k and ε are prepared separately. In my understanding, the residuals of the NavierStokes equation should not be used to train the k or ε network, and similarly, the residuals of the k-ε model should not be used to train the flow velocity network. Is there any way to achieve this in modulus?
Related topics
| Training on loaded meshes | 1 | 666 | June 14, 2021 | |
| I can't create two networks using tensorrt simultaneously in one program | 3 | 740 | October 12, 2021 | |
| Some details wanted about Resnet18 demo network. | 2 | 564 | October 12, 2021 | |
| Two-equation turbulence model | 1 | 1300 | June 21, 2022 | |
| Re-training ResNet_18 | 1 | 1394 | August 6, 2018 | |
| How to improve and train DriveNet or LaneNet in driveworks? | 1 | 909 | March 16, 2018 | |
| The results of turbulence channel flow is not the same as those in Modulus_v22.03.1_User_Guide | 2 | 802 | June 19, 2022 | |
| Segmentation Fault when trying to run a custom network (Solved) | 12 | 1769 | July 20, 2018 | |
| Training DriveNet with custom class and data | 4 | 1522 | October 9, 2018 | |
| Inverse Problem with OpenFoam data: subnetworks | 6 | 870 | October 12, 2022 |
