How to set camera input rather than file input in python app test 4?
opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps/apps/deepstream-test4$ python3 deepstream_test_4.py -i
is it possible to use camera stream input? how? the sample illustrates how to use file input
For camera stream input, do you use nvarguscamerasrc or v4l2src?
@DaneLLL Thank you for following up
I would use rtsp as the concern is the use of ip camera in this case.
To run:
  $ python3 deepstream_test_4.py -i <H264 filename> -p <Proto adaptor library> --conn-str=<Connection string> -s <0/1>
source deepstream_python_apps/apps/deepstream-test4 at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub
Please check the sample to link with rtspsrc plugin:
/opt/nvidia/deepstream/deepstream-5.1/sources/apps/sample_apps/deepstream-testsr/
Looks like we don’t have python sample with rtspsrc. Should be OK to refer to the C sample for customizing deepstream-test4. Please give it a try.
Or may refer to deepstream-test3 for using uridecodebin.
for customizing of this file - test 4 python will it work out if just to put instead of filesrc ->rtspsrc, or if to put entire rtsp path into the line below? https://github.com/NVIDIA-AI-IOT/deepstream_python_apps/blob/master/apps/deepstream-test4/deepstream_test_4.py#L343
You would need replace
filesrc ! h264parse ! ...
with
rtspsrc ! rtph264depay ! h264parse ! ...
And register pad-added signal:
  g_signal_connect (G_OBJECT (source), "pad-added",
      G_CALLBACK (cb_newpad), depay_pre_decode);
