How to set "config-file" path property of nvdsanalytics plugin dynamically every-time I add a new source?
I want to set “config-file” path property dynamically for the nvdsanalytics plugin whenever add a new source to the pipeline. Pipeline should be running always.
• Hardware Platform (Jetson / GPU) Desktop GPU
• DeepStream Version 6.4
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only) 535.171.04
• Issue Type( questions, new requirements, bugs) Question
I tried to set the “config-file” path property inside the add_sources function below but it only works for the first source. For the subsequent sources, it does not work and I suspect the plugin itself do not work for the subsequent sources.
static gboolean on_file_changed(GFileMonitor *monitor, GFile *file, GFile *other_file, GFileMonitorEvent event_type, gpointer user_data) {
    if (event_type == G_FILE_MONITOR_EVENT_CREATED) {
        gchar *uri = g_file_get_uri(file);
        char *arg1 = (char *) user_data;
        g_print("New file created: %s\n", uri);
        add_sources(uri,arg1);
        g_free(uri);
    return TRUE;
static gboolean add_sources(gchar *uri, char *argv) {
    GstElement *source_bin;
    GstStateChangeReturn state_return;
    std::string file_path_in_string(uri);
    g_print("Calling Start %d \n", source_id);
    source_bin = create_uridecode_bin(source_id, uri);
    source_id++;
    if (!source_bin) {
        g_printerr("Failed to create source bin. Exiting.\n");
        return -1;
    if(sink){
      // get the input video file name
      std::filesystem::path file_path_obj(file_path_in_string);
      std::string processed_video_path = std::string(PROCESSED_VIDEO_PATH) + argv + "/" + file_path_obj.stem().string();
      gst_element_set_state(sink, GST_STATE_NULL);
      gst_object_unref (GST_OBJECT (sink));
      g_print("path of the processed video saved : %s \n", processed_video_path.c_str());
      g_object_set(G_OBJECT(sink), "container", 2, "output-file", g_strdup_printf("%s.mkv", processed_video_path.c_str()), NULL);
    g_object_set (G_OBJECT (nvdsanalytics), "config-file", nvanalytics_config_file, NULL);
    g_source_bin_list[source_id] = source_bin;
    gst_bin_add(GST_BIN(pipeline), source_bin);
    state_return = gst_element_set_state(g_source_bin_list[source_id], GST_STATE_PLAYING);
    switch (state_return) {
        case GST_STATE_CHANGE_SUCCESS:
            g_print("STATE CHANGE SUCCESS\n\n");
            source_id++;
            g_num_sources++;
            break;
        case GST_STATE_CHANGE_FAILURE:
            g_print("STATE CHANGE FAILURE\n\n");
            // Handle failure as needed
            break;
        case GST_STATE_CHANGE_ASYNC:
            g_print("STATE CHANGE ASYNC\n\n");
            break;
        case GST_STATE_CHANGE_NO_PREROLL:
            g_print("STATE CHANGE NO PREROLL\n\n");
            // Handle no preroll state change as needed
            break;
        default:
            break;
    return TRUE;
For context, on_file_changed function will be called every time there is a new source video file on the folder.
My pipeline file is also attached.
pipeline.zip (9.0 KB)
please refer to this topic.
Setting the config file path parameter dynamically as above also works. The issue was when I’m modifying the config file for each new source I did not update the stream ID so the analytics rules only applied for the 1st stream.
Tested out this suggested method as well. I works too. Thanks for the support!
